I'm running a size optimization and am trying to get the results in the output .prop file. I enabled the PROPERTY card and set the option to File. It outputs a .prop file but it's empty, it just says "$ PROPERTIES AND MATERIALS AT ITERATION 5" but lists no properties. My model is made of bars with tube cross section.
Does anyone know how I can get it to list the properties? Thanks
