Hello everyone,I would like to customize hypermesh by adding a keyboard shortcut that brings up the following window:
Normally I get it from the following menu:
not exactly a shortcut, but you can always use the 'search' tool (Ctrl+F).
If you type Ctrl+F and then start typing 'shor...'
it will come up, with no need of usng your mouse to open it.
I like it.
I think I'll use the solution.
However I was thinking something like a tcl script, a macro called by keyboard shortcut.
I like it. I think I'll use the solution. However I was thinking something like a tcl script, a macro called by keyboard shortcut.
you can use a csript with these:
