I recently got a new laptop and was wondering if I can install EDEM on that other device. I have EDEM installed on my old device and was wondering if I would need to go through the whole licensing process again.
Hi Jake
It depends on what kind of licensing you had - if you had a standalone license or a server license.
If you had a standalone license, then you would need to go through the licensing process again. If it was a server license, then you just need to make sure that your new system can connect to the server where the license is hosted.
Hope this helps.
Thanks,Jerrin Job
Hi Jake It depends on what kind of licensing you had - if you had a standalone license or a server license. If you had a standalone license, then you would need to go through the licensing process again. If it was a server license, then you just need to make sure that your new system can connect to the server where the license is hosted. Hope this helps. Thanks,Jerrin Job
How do I know that type of license that I had? I am not too sure what kind it is
