How can I calculate average acceleration within the selected time period t1 - t2? Ex: 0.00 - 0.02s
Thank you for answering my question.
Hi Manh,
To do what you describe you should select at the top menu the path /Line Chart.../Query.../Statistics...
Then in the window that appears at the bottom the range you want to use. Here because time values are in X axis, you should select x values from 0 to 0.02sec.
The value you are looking for will be shown in the window at the bottom of your window and is the Mean of Y axis. Additionally, the selected range will be shown in the diagram directly.
See the following image for more details.
