How can you calculate Ld and Lq inductances on FluxMotor?
Thanks in advance for your help.
Jaime
Hi Jaime Maraví,
FluxMotor calculates the Ld and Lq inductances in the Characterization - Datasheet under the TEST menu.
In the Overview window at the Outputs, you will see Inductances.
Also, the dynamic and static inductances are calculated in the Characterization - Model under the TEST menu.
Best regards,
Alexandru
Hi Jaime Maraví, FluxMotor calculates the Ld and Lq inductances in the Characterization - Datasheet under the TEST menu. In the Overview window at the Outputs, you will see Inductances. Also, the dynamic and static inductances are calculated in the Characterization - Model under the TEST menu. Best regards, Alexandru
Thanks Alexandru. Really helpful.
Thanks Alexandru. Really helpful. Regards, Jaime
You're Welcome!
Hi Mr. Alexandru,
Do you know if Ld and Lq showed in Characterization - Datasheet are phase or line values?
