Hi, I would like to calculate the slot filling factor of an emotor built on Flux. It is not easy as the conductors are not physically represented. I want to build it as a parameter and then export it Hyperstudy to run an optimization of the motor. I would then set a constraint not allowing the slot filling factor to be larger than X%.
Has anyone done something like this before?
Kind regards,
Jaime
