Hello I am trying to simulate cross-talk between 3 wires using FEKO/cables. I am doing this in 2 different ways: (1) I define 3x wire cross-section (single conductor), I define 3x cable instances, one for each wire, all taking same path; (2) I define 3x wire cross-sections (single conductor) but place all them inside a single BUNDLE, then I define a single cable instance for the bundle. I have confirmed the 2 approaches have the exact same geometry and mediums/materials, etc. The only difference is that one uses a BUNDLE and the other does not. The outcomes of both simulations are completely different. Is there any ´possible explanation why this would happen?
