Hi guys,
I tried to validate my results of dynamic analysis tools by doing the following:
First I made a static analysis of a blocked shaft with a torque of 82,000 Nm. This load resulted in a force in the blockade of Fres = 330,000 N which created counterforces in the roller bearings of about F1trans = 43,000 N in the fixed bearing and F2trans = 290,000 N in the floating bearing. This result is correct.
After this I tried basically the same analysis but using the dynamic analysis tools. To avoid any oscillation of the entire shaft, which would result in oscillating forces inside the bearing, I introduced the load softly and continuously as I could. See the chart:
The max load of 82,000 Nm and all other constraints and contacts were exactly the same. So I assumed equal resulting forces inside the blockade and the bearings but this wasn't the case and I can't figure out why. The following spreadsheet shows how big the difference between static and soft dynamic analysis was.
| | static | dynamic |
| input | | |
| load/torque | 82,000 Nm | 82,000 Nm |
| output | | |
| Fres | 330,000 Nm | 390,000 Nm |
| F1trans | 43,000 N | 5,000 N |
| F2trans | 290,000 N | 360,000 N |
