Hello
I plot a curve with HG from .T01 file.
For time history output frequency, I set for 100 points.
when plotting, Is there any way to reduce this number of points to 50 or 25?
Tks
Go to the upper menu:
Curves >> plot macros
From the list, choose resample:
Choose your original curve, and define the frequency intended. In my case, i've selected 100 frequency, meaning only points stepping 100 points will be ploted, by using interpolation.
In the end, tehse are the functions used:
the x vector if a range from the first to the last point, but ajusted by 1/100.
and the y is just a linear interponation on this new x vector evenly spaced.
