Some files stop at the cooling step and do not proceed to the wrap step.
How can I proceed to the WRAP process to complete the simulation?
The Cooling process has "* * End time is reached * *" in "c2mRun.out" file and I can see the result.
WRAP process does not display results. And, "c2mRun_warp.err_XXXX.out" is encountered.("XXXX" is any number)
The material in the analysis model is PC (Default) and the virtual mold temperature is 358K, cooling time is 16sec (Remove the temperature setting).
Thank you for the helps.
