simulation using stl file
Altair Community Member
Updated by Dung the most handsome man
Hello everyone,
I have a problem when import stl file into inspire cast. When i set up the problem, the 'open window' show up like this
And i can't set up the condition of the problem.
Thanks.
1 - 3 of
31
OPUpdated by Dung the most handsome man
I have read the c2c getting started document, it even uses stl file directly after import it into the software.
Like this post:
In inspire cast, i don't know how can it set up the condition if i only have stl model.
Thanks.
Updated by Matthieu Pupat
Click2Cast used STL files. Inspire Cast is a different interface with much more functionalities that works with geometry. I hope this helps.
Inspire Cast needs a geometry to setup a problem. Since STL is not geometry but mesh, Inspire Cast pops up the window so that you can import a geometry to work on.
