I am trying for drop test of bottle. i followed Altair tutorial. But there is error of Time step. '**ERROR : TIME STEP LESS OR EQUAL DTMIN FOR SOLID ELEMENTS'
what to do?
Initially, there was Error as,
** ERROR IN INPUT CONSISTENCY ERROR ID : 639
I change element type PENTA6N to PENTA6DG
Apologies for a delayed response.
Please try with the attached model file. There were some issues with the material defined.
Hello George,
Thanks..
Still there is a problem.
1. when I import solver deck sent by you, it shows some error notification.
2. when I run the deck file directly, it shows zero error and 48 warning and run end.
3. when i edit deck file and add control cards as per tutorials it shows errors.
I attached screenshots for each of above.
please help me.
I use Hypermesh v13.0
This is a warning showing that /ALE/GRID/DONEA card is not supported for HyperMesh 13 version.
I tried running in HW 13 version and it ran fine. The files are attached for your reference.
Thank you
When I run your Deck file, it complete analysis.
but when i import it in hypermesh, make changes and save with other name, it gives error.
ERROR ID : 665 ** ERROR IN INPUT FILE DESCRIPTION : CANNOT OPEN INCLUDE FILE: /Oraios
ERROR ID : 980 ** ERROR IN INPUT FILE DESCRIPTION : 1 INCLUDE FILES NOT FOUND
+-------------------+ | BLOCK FREE FORMAT | +-------------------+
Why is it so?
can you send me snapshot of control cards used in your model? because when i opened it there are some unsupported cards
I didn't change any control cards.
I think the changes you make creates error. There is no need of any include file for this model.
No any file is working after run
Please provide the correct .hm or .rad file
Hi Vishal,
could you please explain the issue you are facing?
