I am trying to run analysis of blow molding by referring blow molding tutorial. There is error while running analysis.
Hi Harsh,
Can you please share the model file and engine file through the secure dropbox.
Received the files. There are some modelling errors in the file.
I have send the recommendations, please check the mail.
Hello George,
Received your files and i gone through it. I correct my mistakes. Still there is issue. Model checker show only one warning.
This is a warning which you can ignore. If you still get any issues ,please share the latest model file.
Hi George,
Though Its a warning, my run was stopped. The same problem occurred for corrected model.
Please share the model file with the out files.
The updated files has been sent. Please check the same.
I received files but cant open in HM. I am using HM 13 version
I tried with file u sent. But the problem is still there. Don't know whats wrong?
I tried running the same file in HW 13 version and it ran fine without any issues.
Did you edit something after importing?.
Hi, I tried running the same file in HW 13 version and it ran fine without any issues. Did you edit something after importing?.
No.... I simply run the file u sent....
Please share me the same file with the out file generated.
Hi Harsh, Please share me the same file with the out file generated.
Please find the files in dropbox
This seems like an issue with HyperMesh 13 version. Please check the mail where I have sent a possible workaround.
