I am trying to rotate a plate around axis. I use initial velocity around axis as boundary condition. But when i run the setup in radioss , it shows Error 760.
Need Suggestion to correct it.
you can open the .hm files in Hyperworks.
Hi Ivan,
Can you explain what you mean by opening .hm file in HyperWorks?
Do you mean RADIOSS solver manager?
Hi Prakash,
yes I meant RADIOSS solver manager.
HI,
Looks like Student Edition,
If the number of nodes in the model is over 100,000, the simulation will not start.
I am using commercial licence software Hyperworks v 13.0.
Hi @Harsh2610
Sorry for the confusion, I was pointing to another reply.
Are you still facing the issue with the simulation?
Hi @Harsh2610 Sorry for the confusion, I was pointing to another reply. Are you still facing the issue with the simulation?
Yes.
Harsh,
Hello, I am trying to rotate a plate around axis. I use initial velocity around axis as boundary condition. But when i run the setup in radioss , it shows Error 760. Need Suggestion to correct it.
I am able to run the .hm file you shared as it is.. Please let me know if I am missing something..?
Also, Why not use a rigid wall instead?
Hello Prakash,
Actually, We are working on Bottle stability Test which is currently performed Physically. We want to do it in simulation.
Simply rotate a plate on which a bottle kept and measure the angle of inclination when bottle fall down.
Now in simulation, we tried to rotate the plate by 'Velocity around axis'. But it shows error.
Also do I need to apply gravity load to bottle?
For same test, Previously you suggested for Motion View. But actually, we don't know anything about this software
Hi Harsh,
I am able to run the model you shared as it is. Can you please update the HyperWorks solvers at your end and check if that helps?
You can apply Gravity using BCs Manager>> Gravity load.
Hi Harsh, I am able to run the model you shared as it is. Can you please update the HyperWorks solvers at your end and check if that helps? You can apply Gravity using BCs Manager>> Gravity load.
I tried to run it but again same error. I am using Hyperworks 13.0 . And I don't have rights to update software versions.
