I have a error in my run.
Error trapped Report to listing File.
I deleted Contact interface, and tried again. still same result.
same when tried with no load.
Please try with the attached model file.
hello George,
Thank you very much.
Problem has been solved. What was the issue?
But, It shows too much time to complete run.
We can see that the time step is very low for this run, that is e-12 which causes huge run time.
From the engine out files check what is causing this issue. It could be an element, or node or interface.
For an element, check the related material.There must not be an error in the units system that this data is given in. check the element size also.
For a node, check the characteristics of connected elements. If the node is on the master side or the slave side of an interface, this interface must be verified.
For an interface, the gap of the interface must be verified if some failure happens on the master or the slave side of the interface. Also check the interface for any penetrations.
Finally ensure that the unit consistency followed in the model is correct.
