I am doing an analysis in radioss. Run started withou any error but after that 'Remaining time' is increasing .
What to do?<?xml version="1.0" encoding="UTF-8"?>
As the time step drops the run time will increase.
From the engine out files check what is causing this issue. It could be an element, or node or interface.
For an element, check the related material.There must not be an error in the units system that this data is given in. check the element size also.
For a node, check the characteristics of connected elements. If the node is on the master side or the slave side of an interface, this interface must be verified.
For an interface, the gap of the interface must be verified if some failure happens on the master or the slave side of the interface. Also check the interface for any penetrations.
Finally ensure that the unit consistency followed in the model is correct.
Hello George
Thank you for rply
I go through .out file. But actually I don't know what to check and what is mentioned there for issue. I cant find anything there.
Please guide me accordingly. Files are shared with you through secure file dropbox
Any updates on my Query?
I have already sent you the update model via mail.
Hello George,
I have received your mail. I will try with that model.
But can you tell me what is the mistake?
And how to check it in .out file?
