I am doing a simulation for a bottle in which a bottle is rest on a surface. I make the surface inclined. I want to check inclination angle of surface exactly when the bottle fall down.
Please suggest me some idea how it will work
Apply a gravity load on the bottle component and tilt tilt (rotate) the surface. When the tilted angle is exact the bottle will roll down.
This you may have try with some iterations.
Hello george,
Thank you.
i will try it
I am doing a simulation for a bottle in which a bottle is rest on a surface. I make the surface inclined. I want to check inclination angle of surface exactly when the bottle fall down. Please suggest me some idea how it will work
This seems to be like an MBD problem rather than radioss as only angle of inclination needs to be known or even simple mechanics will work for this.
Hi, This seems to be like an MBD problem rather than radioss as only angle of inclination needs to be known or even simple mechanics will work for this.
If it is only to do with inclination, yes this can be done with MotionView/MotionSolve.
