hello
i m trying to make h3d from .fem. i m doing as it is tutorial in MotionView/MotionSolve which are available @ http://www.altairuniversity.com/learning-library and search for motorcycle.
i created my own motor cycle frame in optistruct then i meshed it and created rigid components.
like
then i followed the Generating a Flexible Body for use in Altair MotionSolve - RD-4030
https://www.sharcnet.ca/Software/Hyperworks/help/hwsolvers/hwsolvers.htm?rd4030.htm
then i did optistruct and created .fem file
while importing that file
error message came:
*** OptiStruct defaults set from:
install config file: C:\Program Files\Altair\13.0\/hwsolvers/optistruct.cfg.
NOTE # 9199
MSGLMT=STRICT is active, all messages will be printed.
You can suppress some less important warning messages by use of
MSGLMT=BRIEF or UNREF (in config file or in the input data).
2 PARAM(s) were set:
COUPMASS,-1
CHECKEL ,YES
*** INFORMATION # 741
No need to constrain the rotational d.o.f. of this dependent grid.
RBE2 element id = 1309054
independent grid id = 237100
dependent grid id = 5
This is because there isn't any stiffness and load on the rotational
d.o.f. of the dependent grid.
dependent grid id = 6
dependent grid id = 7
*** INFORMATION # 742
The dependent rotational d.o.f. of this rigid element is removed.
RBE2 element id = 1309055
independent grid id = 237106
a dependent grid id = 83333
This is because there is no need to constrain the rotational d.o.f. of
any of the dependent grids.
RBE2 element id = 1309056
independent grid id = 237103
a dependent grid id = 14115
*** INFORMATION # 743
The total number of grids whose rotational d.o.f.s need not be
constrained in RBE2 elements is 1468.
The total number of rigid elements, whose rotational dependent d.o.f.
are removed because there is no need to constrain those d.o.f., is 2.
*** ERROR # 176 ***
A dependent d.o.f. of rigid elements is constrained in an SPC set.
grid id = 1
component = 1
SPC set id = 0
*** ERROR # 176 ***
grid id = 1
component = 2
SPC set id = 0
*** ERROR # 176 ***
grid id = 1
component = 3
SPC set id = 0
*** ERROR # 176 ***
grid id = 1
component = 4
SPC set id = 0
*** ERROR # 176 ***
grid id = 1
component = 5
SPC set id = 0
*** ERROR # 176 ***
grid id = 1
component = 6
SPC set id = 0
*** ERROR # 176 ***
grid id = 2
component = 1
SPC set id = 0
*** ERROR # 176 ***
grid id = 2
component = 2
SPC set id = 0
*** ERROR # 176 ***
grid id = 2
component = 3
SPC set id = 0
*** ERROR # 176 ***
grid id = 2
component = 4
SPC set id = 0
*** More of ERROR messages # 176 were suppressed...
then
.h3d not created
please help me
my objective is do optimization of my motorcycle frame
and to apply loading condition i want to use motion solve to extract loads
then do topology optimization to get new optimized design.
exactly same as
my problem is i m not able to create h3d file
i want to know what load steps i use to create successful result
regards
santosh
