Error# 2148: Invalid design problem.
User: "Sam George"
Altair Community Member
Updated by Sam George
I am doing a topology optimization with objective to minimize the thermal compliance.
I get the following error.
 A fatal error has occurred during computations:
  *** ERROR # 2148 ***
  All the sensitivities of response 2 (objective) are zero.
I have attached the .out file, I would like to know what the possible reasons for this error could be.
Would there be any example files to share if there is a topology optimization involving CFD and thermal inputs with Optistruct.
1 - 1 of 11
    User: "RobHoglund"
    Accepted Answer
    Updated by RobHoglund
    Hello Sam,
    The Thermal Compliance is extremely high for the heat transfer subcase.
     Subcase  Thermal Compliance
           1  3.494810E+20
    Can you check and review your model unit system for the heat transfer analysis and the fixed temperatures and thermal loads?
    You can run a baseline analysis without the optimization on the model to check and see if the temperature results make sense first (use run option -optskip).
    OptiStruct also has Darcy Flow topology optimization capability for flow channel optimization considering heat transfer.  See here:
    https://help.altair.com/hwsolvers/os/topics/solvers/os/darcy_flow_analysis_intro_r.htm?zoom_highlight=darcy+flow
    Thanks,
    Rob H.
