I tried to model the following example question in Roak's Formulas for Stress and Strain book. General equation for the deflection of the load is shown in the Figure 2. 10587755.305 psi is used as the Young's modulus (E). So, the final result should be 7.33e-06 inches which is not the value I got from SimSolid. Attached files are as follows.
Figure 1- Question
Figure 2 - Equation
Figure 3 - Model Setup
Figure 4 - Results
Requesting your help to get accurate results.
