Dear support,
The system includes a spining aluminum disk and two permanent magnts over it from its sides.
After solving the model, it looks like no magnetic torque was aplied on the disk.
We would like to ask for your help in finding the way for defining the simulation correctly and find a relation between the disk angular velocity and the magnetic torque.
I suspect that the mechanical set in the project is not properly defined and causing problems.
thank you for your help
