Hello Team,
Need everyone's help again. I have a process that currently uses a macro in the beginning and then formatting at the end this is a two part process and is done by two separate people I am hoping to eliminate the split work by putting everything in DPS.
The Macro takes a report does some basic formatting and then creates a pivot based on assignment number to assign a responsibility to it. Then brings the assignment back into the original table and deletes the pivot.
My data starts out looking like this
I sum it like this and assign a value based on different calculations like line is C=C and D=0 assign it to No Receipt, ect...
| 1736100005 | 12 | 12 | 0 | -12 |
| 1736100011 | 12 | 12 | 0 | -12 |
| 1736100012 | 3 | 3 | 0 | -3 |
| 4126100549 | 27 | 27 | 0 | -27 |
| 4126100546 | 17 | 17 | 0 | -17 |
Is there anyway that I can create an assignment for these items and bring that value back into the original sheet? Does not look like grouping or summaries will work is there any other way?
High level the macro makes a pivot, assigns a role, and then does a vlookup to insert the role back into the original sheet. Not sure how to do this in DPS.
Vanessa Tanner
Manager Optimization Services
Gap Inc Store Labs
San Francisco NM
(505) 462-0455
