I have 1-D elements in my model as Cbar elements,need to extract shear force even requesting ELFORCE=ALL the output cannot shows any data.
Can you please suggest a way how to extract Shear force from BAR/BEAM element?
ELFORCE is supported for bar and beam elements.
Can you try with PBEAML and check if that helps?
If not, please share the model file.
