simlab with optistruct - nonlinear temperature load
User: "felixWang"
Altair Community Member
Updated by felixWang
hello
i am new user for simlab 2019.2 . And now i want to simulate a nonlinear problem that about 2 combine plate with a thermal load by time varied. For example, all simulated body heated from 300K to 400K in 20s.
I want to analysis the stress and strain by time varied.
Can i got some tip or material ?
THANKS!
1 - 3 of 31
    User: "alpha_21885"
    Updated by alpha_21885
    Can you share what kind of nonlinear you want to simulate(Contact, Material, large strain)?
    <?xml version="1.0" encoding="UTF-8"?>1639318256_nh.thumb.png.c50d35d5deee46beb0f9c7b686af427e.png
    User: "felixWang"
    OP
    HELLO
    THANK for your reply.
    My study is the reliability of electronic plate analysis. I want to simulate the object heated and cooled (thermal cycle test), then got the stress and strain.
    The temperature condition like this,  and my model is just a simple PCB (3 piece combined)
    image.png.57fd58cc296759f57db50b96a678b581.pngimage.png.4c5ed5bbbd5c6fdc8a24f543ef24e1c9.png
    How is the problem solver by using SIMLAB ?
    THANKS
    User: "felixWang"
    OP
    HELLO
    <?xml version="1.0" encoding="UTF-8"?>image.png.57fd58cc296759f57db50b96a678b581.png<?xml version="1.0" encoding="UTF-8"?>image.png.4c5ed5bbbd5c6fdc8a24f543ef24e1c9.png
    THANKS
    HI ALPHA
    I study some paper like simulation the thermal cycle, another paper analysis the results
    how can i do this job in simlab?
    THANKS
