interactive 2D mesh
User: "Pandurang"
Altair Community Member
Updated by Pandurang
Hi All
working on 3D flange having holes..i m trying to write script for 3D mesh of it..
process i am following is :
1. washer split for holes.
2. 2D Automesh surfaces
3. Solid map
I want 2D Automesh process to be interactive so that user can adjust mesh around holes to create good washer..
How can i do this..?
PD
1 - 5 of 51
    User: "QuyNguyenDai"
    Updated by QuyNguyenDai
    Can you do this without script?
    User: "Pandurang"
    OP
    yes
    User: "tinh"
    Updated by tinh
    When you use hm_pushpanel to invoke panel 'automesh' to help user to adjust mesh, hm_pushpanel will return soon and not wait for user finish his work.
    => do not use hm_pushpanel, you need to pack all remained script into hm_setpanelproc
    example:
    eval *createmark surfs 1 $::FlangeSurfs
    set Holes [p_GetHoles surfs 1]
    hm_entityrecorder surfs on
    p_SplitHoles $Holes
    hm_entityrecorder surfs off
    eval lappend ::FlangeSurfs [hm_entityrecorder surfs ids]
    hm_setpanelproc {
         hm_setcollector automesh [hm_getcolnumber automesh 1] surfs
         hm_initpanel {
              hm_activateitem [hm_getitemnumber automesh mesh]
         hm_callpanel automesh
         eval *createmark elems 1 {'by surface'} $::FlangeSurfs
         p_SolidMap elems 1
    User: "Pandurang"
    OP
    Hi Tinh ,
    This info is really helpful but..
    p_GetHoles
    p_SplitHoles
    p_SolidMap
    These are invalid commands....
    User: "tinh"
    Updated by tinh
    Of course, you have to write them. I just suggest a flow.
