 I want to do a non-linear static simulation on my model.
 I imported the TABLES1 data, but I have the simulation which displays an error message.
 Here is the message:
    A fatal error has been detected during input processing:
   *** ERROR # 3015 ***
   The first point (X1,Y1) specified on the TABLES1 bulk data entry ID=1
   does not satisfy (zero,non-zero) requirement. The initial yield stress
   can not be zero.
  *** Run terminated because of error(s) in the input data.
   in image the data of my TABLES1
   I don't understand or have the problem.
 Thank you for your help.
   the file also as an attachment
