I was simulating a windscreen antenna in FEKO using windscreen solution and I got the results as I expected. I used a plane wave as a source and calculated the currents at the windscreen antenna by placing a wire port between two wires. But when I introduce a CAR into the model, and simulate the windscreen antenna along with the car then I do have different results. I am not sure why?
I performed the same process in other tool (CST) and I got the results what I expected. But in FEKO they are different. I am not sure whether I need to consider any special settings in case a car model is introduced in FEKO. Could you please give me any suggetsions ?
