Hello
I have designed a patch array antenna and I am trying to create a gerber file in order to produce it. However, when I create such, using FEKO export option, I don't see in the created gerber file any data about the patches, holes and other antenna elements.
Attached the antenna FEKO design file and the created GBR file.
What is the proper way to create gerber files from FEKO for production purposes?
Thanks.
