Implementing user tire model
User: "Bart van de Sande"
Altair Community Member
Updated by Bart van de Sande
Hello everyone,
Currently I am trying to implement an user defined tire model in Motion View. For this I want to use a matlab script (.m file) in which all the necessary tire forces/moments etc. get calculated. I understand that I need to make a .tir file which specifies the type to 'USER' so that Motion View knows to look for a user specified model.
However, the next step is loading a dll file with the matlab function inside. I tried creating a dll folder with the matlab coder, but when I am trying to run a model it is unable to load this dll file.
Does anyone know how to load a matlab script as a tire model in Motion View?
Thanks in advance,
Bart
1 - 5 of 51
    User: "Praful"
    Updated by Praful
    Hello Bart - Would a User-defined force work for you?
    Regards
    Praful
    OP
    Hello Praful, thanks for the quick reply!
    When I use such a user-defined force, am I able to take some parameters from the model as inputs?
    Especially inputs from the road which the vehicle will be driving over are required to model a tire. When an autotire entity is used, this road is also simulated and taken into account. But I am not sure how to access the road data with such a user defined force.
    Kind regards,
    Bart
    User: "Praful"
    Updated by Praful
    Kind regards,
    Bart
    Yes, you should be able to pass parameters from the model. You may want to refer to the User Subroutine section of the help in MotionSolve.
    Accessing road data part, I am not sure. You can pass the road data file and the position of the wheel to your code that may get the road interpolation.
    If you are looking for using the MotionSolve tire feature where it provides the road data but with your own tire calculation, I don't think it is possible.
    Regards
    Praful
    User: "Sonu Manjhi_20605"
    Updated by Sonu Manjhi_20605
    Hi Bart,
    Can you please share the log file of your simulation? And if possible, can you share the dll that you have created?
    I want to check if the function is exposed in the dll.
    Thanks,
    Sonu
    OP
    Hi Bart,
    Thanks,
    Sonu
    Hey Sonu,
    I created a simple tire model which just assigns some static values to some of the tire parameters for now, in order to test whether this structure with the dll worked.
    I added the log and the dll file to this message
    Kind regards,
    Bart
