Hi, im trying to do a analysis on optistruct and i need to apply 2 moments but i dont know how to do it, because in the load step i can only select one of them.
Thanks.
Hi Daniel Lopez,
for this you can create another load collector with the "Card Image" LOADADD and put both of your moments in the set.
or simply put 2 moments into 1 load collector (use panel Shift+F11 to move loads into load collector)
and refer that load collector in loadstep definition
