I am Adib and doing thermal analysis on resistance spot welding using Optistruct. Now I am having problem with the result. I got error which show *** ERROR # 2933 *** There are more number of degree of freedoms with double dependency than the number of independent degree of freedom near grid ID 1306. PARAM,AUTOMSET is ineffective in this situation.
I do not know how to settle this error. Hope some help from you.
Attached is the file of my model. Thank you.
