I just started learning Feko with a student license and today I got it installed on a remote PC at work which I'm accessing from a laptop. I created a model of the Aperture Coupled Patch Antenna example from the Example Guide and when i tried to run a simulation I got the following error:
ERROR 3978: Internal Feko error. Please notify the Feko support team and provide the error number, preferably together with the Feko input and output files.
ERROR 20032: Error opening the source file "aperture coupled patch_fr_1_ada_1.out" for copying.
I tried running Feko as an administrator but the problem still remains.
In the ZIP file you'll find the model and the additional files. If needed I can also attach the license file that I've used for the installation.
Kind regards,
Plamen
