Error 1458
Manuel_21421
Manuel_21421 Altair Community Member
edited May 2021 in Community Q&A
Hey everyone, I´m working on a model, which I imported as a CAD file, created the middle surfaces and now I wanted to run Optistruct to see the applying forces. But I always get the following error:
*** ERROR # 1458 *** in the input data:
One of following cards must be used in this subcase:
METHOD(STRUCTURE), METHOD(FLUID).
Can someone explain, where to change this setting?
Thanks,
Manuel
  • Adriano_Koga
    Adriano_Koga
    edited May 2021
    can you check what analyhsis type is defined into your loadstep?
    Usually these cards are needed for 'normal modes' analysis (modal analysis).
    You should probably change the analysis type to 'linear static'.
    Then use SPC for your model contraints and LOAD for selecting your forces.
  • Manuel_21421
    edited May 2021
    Where exactly can I check this, or where can I change the type to "linear static"?
  • Adriano_Koga
    Adriano_Koga
    edited May 2021
  • Manuel_21421
    edited May 2021
    wow thanks, that worked!
    But now I get another error:
    *** ERROR # 1000 *** in the input data:
    Incorrect data in field # 3. Field 'PID' of CTRIA3 bulk data.
  • Adriano_Koga
    Adriano_Koga
    edited May 2021
    Hi @Manuel
    This error is showing your have missed the property assignement into your mesh. PID stands for Property ID. Go to your component and add the property into your component.
    The post below shows some tips for error 1000.
    https://community.altair.com/community?id=community_question&sys_id=3c76043a1b2bd0908017dc61ec4bcbed
    I'm not sure how familiar you are with HyperMesh and OptiStruct, so i would suggest you to take the online training courses in Altair University to get more familiar with it too. I believe it would be helpful for you.
