Dear all,
1) In the Activate on-line help, ports of Brake Modelica block are described as:
f_normalized.
Support/housing of component
support.
Optional port to which dissipated losses are transported in form of heat
heatPort.
Normalized force signal 0..1 (normal force = fn_max*f_normalized; brake is active if > 0)
Is thi correct? It should be:
f_normalized.
support.
heatPort.
Correct?
2) I turned on the support port and attached a spring/damper block to it, but the model issued an error. Please let me know how to use the port.
I attached the model. Please let me know how to modify it.
Minoru Yubuchi
