How to merge front and rear half car model for full vehicle simulation?
Sudip_Chavan
Sudip_Chavan Altair Community Member
edited February 2024 in Community Q&A
Hello Everyone,
I have built custom front and rear half car MBD model. I am able to run all kinematic and compliance analysis test on both models individually. For the furthur development I am looking for full vehicle events with driver.
Can anyone help me out with the process of merging both models together with driver?
Thanks and Regards,
Sudip Chavan
Best Answer
  • Christopher_Fadanelli
    edited February 2024 Answer ✓
    Hello Sudip,
    What you will need to do is export each required system in both half car models. In a new session, use the assembly wizard to create a full vehicle model. Once that is done, you will need to delete the systems you are going to replace. Then import those systems from your half car models. For adding full vehicle events, it will be the same process as adding an event for half car model. The task wizard.
    To observe a demo on how to export/import systems for your vehicle model, please refer to our free eLearning: https://learn.altair.com/course/view.php?id=497
    For more information on the type of events with Altair Driver, please refer to this link: https://2021.help.altair.com/2021.2/hwdesktop/mv/topics/chapter_heads/full_vehicles_with_driver_r.htm
    Best,
    Christopher Fadanelli
    Application Engineer - Multibody Dynamics
    Troy, MI
  • GTT Adam
    GTT Adam
    Hi Sudip,
    The assembly of these models can be simply completed by exporting one of the Systems as a System Definition. In your rear car model, simply go to File >> Export >> Model >> MDL Definition. Then, in your front car model, go to File >> Import >> MDL Definition. You will then have to manually connect the models using joints/etc. from that point.
    Hope this helps!
    Adam Reid
    Hello Sudip,
    Best,
    Troy, MI
  • Sudip_Chavan
    Hi Sudip,
    Hope this helps!
    Adam Reid
    Thanks Adam! It is helpful.
  • Sudip_Chavan
    Hello Sudip,
    Best,
    Troy, MI
    Thanks Christopher! It is helpful.
  • Sudip_Chavan
    Greetings!
    I have merged front & rear half car model successfully and added Altair Driver & Altair Driver file to run full vehicle events. I'm currently facing following errors during model check.
    1. Unknown symbol sys_tires.m_road_ref_frnt.l...Error resolving entity Path reference marker under Model-Altair Driver. [General]
    2.Unknown symbol "att_path_reference.id" in expression:...att_path_reference.id...Templex error evaluating text under Model-AltairDriverFile 0-Altair Driver. [General]
    When I deactivate Driver and driver file then model check doesn't pop up any error as above.
    There's no any option to edit markers in driver/ driver file. How to change it?
    Best Regards,
    Sudip Chavan
  • Praful
    Praful
    Hello Sudip / Chris
    I guess you should not need to delete each system and re-import them in the full vehicle model. Assuming the front and rear half car models are built from the library and the same library, you could follow the following steps
    1. From each model (front and rear), export model, data only. (File > Export > Model) to mdls
    2. Build the full vehicle model with the same set of front and rear systems using the same library.
    3. Import the exported models (File > Import > Model)
    you should have the full vehicle system configuration matching with the half cars.
    Regards
    Praful
  • Sudip_Chavan
    Hello Sudip / Chris
    Regards
    Praful
    Hello Praful,
    I've customized my front and rear suspension systems with a unique combination of bodies, joints, markers, and forces after initially creating them from template models. Rebuilding them from scratch in a full vehicle scenario would require additional effort. Instead, I exported my customized models using MDL statements and then imported them into the full vehicle template model. This process seems to have merged them properly, as there were no warnings or errors during the model check.
    After adding Altair Driver and AltairDriverFile, I encountered the following errors:
    I noticed that there's no option to edit markers in the driver or driver file. Could you please advise on how to change them?
    Best Regards,
    Sudip Chavan
    Greetings!
    Best Regards,
    Sudip Chavan
    Hi Sudip,
    Can you confirm that the Altair Driver Attachments are set up properly? In 2021.2, go to Altair Driver -> In panel area -> choose attachments.
    There you can check the Path reference, "att_path_reference.id"
    Can you also double check the attachments for the auto tires. " Unknown symbol sys_tires.m_road_ref_frnt.l" This is referring to the AutoTires system -> "Road reference Marker Front -Left".
    Best,
