I am making a simulation for the bush fitment analysis (explicit) and I have a query about sensors for the attached function curves. Basically, a guide pin will be pushing the bush against a solid component, which is fixed, and uses the imposed velocity curve as shown in the function 1 picture. However, after reaching certain reaction force, I want to use a sensor such that function 1 imposed velocity is deactivated and at the same time function 2 imposed velocity to be activated (which is for the guide pin to go up). The total running time of my simulation is around 12ms. However, I do not know the time when the force is going to reach the certain value when the bush is pressing against the component. So I am thinking to use the sensors option in the Radioss for activation and deactivation of the imposed velocity curves. Please suggest a way to make use of sensors for this kind of setup.
Thank you in advance
Akash
