Hey Altair and Radioss Community,
I think I have solved my problem myself, but just to make sure I am correct. I want to simulate a tube crush and the tube is attached to a rigid surface at the top and bottom (picture). I have attached the tube to the surface with type 2 interface.
- To make the internal contact, I set up a type 7 interface with the tube and surface as the master and slave elements. Since the smallest element side length of the tube is much smaller than the surface thickness, the gap was smaller than half the thickness of the surface. As a result, I saw that the tube was penetrating the surface.
- To eliminate the problem, I set up 2 Type 7 interfaces, where:
- one only for the tube itself (master and slave element) with a gapmin of the smallest element length of the tube.
- The other interface was for the contact between the tube and the surface (main layer and slave tube). As Gapmin half the thickness of the surface
So I cant just simulate the surfaces as they are without regarding the thickness as I read everywhere. Am I right?
Best regards
Leopold
