I have been tasked with investigating how to speed up our solve time with parallelization and GPU acceleration. Unfortunately I have found that these acceleration methods have no meaningful effect on the Result generation process. For my current testing solve the WALL time for results is more than 4X longer than the actual solver time. There is also zero parallelization occurring during the result generation process as WALL and CPU time are nearly the same. We are currently outputting results in the h3d format. While the result process is going on if I check hardware activity one core shows elevated usage but that is still only 50% or so, read/writes to the SSD negligible, RAM usage stays constant so I am not even sure what is preventing it from going faster.
1.) Is there a format that would give results faster with similar file sizes?
2.) Is there a way to parallelize or speed up h3d file generation?
3.) What is the bottleneck (CPU, RAM, HDD/SSD) during the result generation process?
