Express forces in different systems
I'm completely new to Hypermesh and struggling. I would appreciate your help.
I did a Python code that deals with rotation and translation of coord systems to express forces and moments in different systems. I wanted to use Hypermesh to check my code by creating examples.
So is it possible to get the coordinates of a force in a local coord system after have defined it in another system in Hypermesh ? I don't want to rotate of modify the force in itself but rotation a coord system and get the coordinates of the force in a new system.
I tried but without success for the moment.
Thank you for your help.
Hi
I am not quite sure if I understand what you need, but if you already run the model and have the results:
Within HyperView, you can create a local coordinate system and refer to it when ask to contour vector results
I hope this is helpful
Regards
