Hi!
I am modeling an organic object. I tried using all the tetramesh options but no matter what I do, I can't seem to get my elements to be about ~1.5 elements. I'm getting a significant range from 0.5 to 3. The only solution I've found so far was to use solid optimization but that takes a very long depending on how strict my criteria is. I simply want elements that are between 1.0 and 2.0 when an idealized goal of 1.5. I plan to take my model to do explicit analysis but that is very difficult if I can't control for small elements. But I also cannot have very large elements because I have material properties that are size dependent.
Would anyone have experience enforcing a tight range (relatively?) of element sizes? Do I have to use other elements to get a uniform size? If so, would they fit organic shapes well?
