As the title states, I always get this error:
Error: No user profile or template file loaded.
My code still ends up running, so I'm not too concerned but it is annoying as it clutters the command terminal space when I view key information.
Do you have the profile option defined when you start HyperWorks?
Maybe something like -profile HyperworksLauncher?
Can you clarify with a command terminal example?
This is would be my command line:
.\hmbatch.exe -tcl <file.tcl> -uAbaqus -aStandard3d
Can you clarify with a command terminal example? This is would be my command line: .\hmbatch.exe -tcl <file.tcl> -uAbaqus -aStandard3d
Ooh sorry. That applies to starting HyperMesh with a script, not running in batch.
