Hello experts,
My model is validated but yet under Mesh > Repair it is indicated that there are free edges.
So far my solution seems to be stable.
I need your advice regarding what should be done about this.
Thanks.
Does the solution in post (contours, etc) also look reasonable? It seems highly unlikely the volume mesh would be created if there were actually free edges in the surface mesh. Maybe some tolerance value set somewhere? I wouldn't be concerned with that if everything seems to work - but it is odd. You could attach your HWCFD database - or you can create a support ticket through your AltairOne account login and attach it there.
