Hello experts, Why is acuview re-computing Hemicubes when I restart the solution. It should be using the previous data right?
Thank you
The default behavior for restart is to go through everything again (acuPrep, acuView) in case things have changed.
I would try adding -do prep,solve to your launch command, so that it skips the view factors step. It should then re-use what is already on the disk.
The default behavior for restart is to go through everything again (acuPrep, acuView) in case things have changed. I would try adding -do prep,solve to your launch command, so that it skips the view factors step. It should then re-use what is already on the disk.
should I add "-do prep,solve" in additional arguments?
should I add "-do prep,solve" in additional arguments? Thank you
Yes - that is where you would add those options.
