I'm trying to model a air gap between stator and rotor of motor where the stator and rotor are concentric cylinders and air is present in the annular space. The circumferential wall of the inner cylinder is specified as moving wall with the tangential velocity of 47m/s ( according to the rotor's speed of 6000rpm)
But the velocity contours i got isn't meaningful, no slip effect is not found. The maximum velocity I got is around 2900m/s which is much higher the velocity of moving wall.
I have attached my input file and post images for reference. Please let me what's wrong with my model/ boundary conditions. Thanks.
