Hello
I have material law 10 for concret in g cm Mus I would like to convert it in N-g-mm-ms units.
Are there any way of soft can coverting this law automatically?
Thank you in advance for your attention and for your support.
Regards
Hi Dr Dhafar Algalib,
The material with the g,mm,mus can be defined with its own unit system (/UNIT) in the model defined with N,mm,ms unit system (/BEGIN) as you can see attached file.
This model (+ nodes and elements) can run directly in Radioss and the unit converted values will be printed in the starter output file.
When the material unit system (/UNIT) is deleted in HyperCrash, the material parameters are automatically converted to the main model unit system (/BEGIN).
Best regards,
Erwan Mestres.
Hi Dr Dhafar Algalib, The material with the g,mm,mus can be defined with its own unit system (/UNIT) in the model defined with N,mm,ms unit system (/BEGIN) as you can see attached file. This model (+ nodes and elements) can run directly in Radioss and the unit converted values will be printed in the starter output file. When the material unit system (/UNIT) is deleted in HyperCrash, the material parameters are automatically converted to the main model unit system (/BEGIN). Best regards, Erwan Mestres.
Thank you Erwan,
I appriciate your attention and this feedback.
Kind Regards
Dhafar
