When I was installing my trial license, that error appeared me: Could not set proxy hostname due to error 5. Error message: unable to write HHWU
config.
Does somebody know what is it about
HHWU writes the license token that you authenticated in C:\Users\<username>\AppData\Local\.altair_licensing\<hostname>\altair_hostedhwu.cfg
The error indicates that there is no write access to this folder or file. If you are using linux, then the same file is in the home directory.
