How can i connect beam element with shell element in explicit analysis? I want all forces in 6 dofs can be transmitted between beam and shell. I tried using rbody, select shell nodes and one of the beam node as slave but beam starts to rotate while analysing. Then, tried type 2 contact but it is still the same. Are there any other solution? i attached a drawing.
