PBS postgres pbs_datastore service is not starting even after restart. Postmaster.pid file is corrupted.
User: "Ayan Banerjee"
New Altair Community Member
Updated by Ayan Banerjee
My PBS_version = 14.1.0
Could not delete using rm -f postmaster.pid command.
The file does not go away after restart.
Both images are given to describe the problem.
qstat or any other pbs_command not working giving err_no=111.
Previously prostgres pbs_datastore used to start but not starting. Tried restarting PBS but not starting.
Error message is /PBSHOME/datastore/postmaster.pid gives input output error.
I tried to remove this file rm -f postmaster.pid. But it also gives input/output error. The file shows all attributes as question. Cant remove it as root.
No comments on this post.
