I am using the "Coil Loss Models" in FLUX to calculate the skin and proximity effect losses in the stator winding of a high-speed motor. I am carrying out the study using 2D Steady-State simulations.
I have couple of questions about the tool.
1) Does the detailed model work with voltage-fed models (FE domain coupled to a circuit with voltage sources)? or do we strictly need current-fed models?
2) Does the resistance value in the red box represent the DC winding resistance of the active regions except the endwinding calculated by the software? also, do I need to insert a value in the blue box? what does this value would represent?
To model the endwinding (3D effect accounted by the coupled circuit), I am adding a separate resistance (green box).
Thank you in advance for your help and support.
Marco
