I am trying to model deformation of foam in Optistruct (Non linear quasi static, NLSTAT subcase) by imposing displacement of top plate through the foam and constraining the bottom plate.
Though my model is converging, you can see the foam penetrates the bottom plate (green).
Three contacts have been defined in the model, 1) Top plate (Prop) and Foam (Nodes) with PCONT/PCONTX7 2) Side plate (Prop) and Foam (Prop) with Static Fric and 3) Bottom plate (Prop) and Foam (Prop) with Static Fric. (Master and Slave order being followed).
Can you suggest a way to overcome this problem?
Thanks,
